3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#1200066 01/17/2017 12:53 PM
Seems like IFS has been done to death yawn yawn. Is there a documented 4X4 conversion? I want to convert a 2 ton to 4X4 w/ manual trans and a mild lift w/ slightly oversize tires, and a dump flatbed. I can see it in my mind, but I haven't seen it done before.
M Online: Happy
Been done many times. Most folks find a donor 4x4 and just swap bodies. Beauty of this approach being the great vintage body with modern brakes, suspension and running gear.
added in edit: Just found this.
http://www.fourwheeler.com/features/0310or-1947-chevy-tk-truck/
RonR
1970 340 Duster
1964 CJ5
Crusing in the Passing Lane
I used modern axles, disc brakes front and rear, Scout power steering box, 241 transfer case, NP-541 trans on my first '47 GMC pickup, got factory full width fenders for front, works well, don't know if would have been easier to use modern frame, but that is another good option. I have a Dodge Cummins 4x4 pickup frame complete from gentle rollover, just looking for appropriate older body to put on it.
Ed
I swapped the running gear of a 76 Chev Blazer into my 55 1/2 ton. I am using the 203 transfer case with a part
time conversion kit. That gives me 12 bolt differentials and 3.73:1 gearing.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
