| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | Seems like IFS has been done to death yawn yawn. Is there a documented 4X4 conversion? I want to convert a 2 ton to 4X4 w/ manual trans and a mild lift w/ slightly oversize tires, and a dump flatbed. I can see it in my mind, but I haven't seen it done before. | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Been done many times. Most folks find a donor 4x4 and just swap bodies. Beauty of this approach being the great vintage body with modern brakes, suspension and running gear. added in edit: Just found this. http://www.fourwheeler.com/features/0310or-1947-chevy-tk-truck/
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I used modern axles, disc brakes front and rear, Scout power steering box, 241 transfer case, NP-541 trans on my first '47 GMC pickup, got factory full width fenders for front, works well, don't know if would have been easier to use modern frame, but that is another good option. I have a Dodge Cummins 4x4 pickup frame complete from gentle rollover, just looking for appropriate older body to put on it.
Ed
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I swapped the running gear of a 76 Chev Blazer into my 55 1/2 ton. I am using the 203 transfer case with a part time conversion kit. That gives me 12 bolt differentials and 3.73:1 gearing. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
