6 members (Joe H, Hanks custodian, dt235sd, Chris's 46 / 515, carbking, Goach2), 70 guests, and 6 robots.
Topics128,188
Posts1,057,216
Members48,465
anybody know where I can get one of those adapter brackets to replace my single master cylinder under the floor of my 46 1/2 ton
Hoozat
I fabed a bracket myself for the dual master I use. Send me your email and I can send you a short write-up and some pictures.
George
[email protected]
Y
yar Offline
Y Offline
I did what George did, fabed a bracket for a tandem MC for my '36 PU. It was pretty simple and uses a modern MC push rod threaded for the original '36 clevis. The system also uses 2 Wilwood 10 pound residual pressure valves.
Ray
thanks guys, just need to figure out what type of heavy metal to use
Crusing in the Passing Lane
Why do you need some 'heavy metal'?
Ed
so when I step on the pedal, the master cylinder doesnt move
Y
yar Offline
Y Offline
hoozat,
If you invent your own MC mount would you mind posting a picture. I'd be curious how it compares to the one I made for my '36 PU just recently.
A big part of the fun of this hobby is the endless opportunities to do these upgrades on the vintage iron.
If you're in a rural area and metal stores don't exist one potential source may be Home Depot. I've seen various flat bars there. On my MC mount I used some 3/16" plate that was left from a cross member I made for my son's '66 Chevy PU.
Ray
Hears what I did on my 37 Panel. brake brackets
1937 Chevy 1/2 ton panel
back yard wrench turner
Here is how I mounted my master cylinder
click
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Moderated
Moderated
Wayne, what did you use for your master cylinder? I'm looking for a dual for my 42 1.5 ton.
Hi 42Buffalo, Welcome to the best forum on the net. Take a couple of minutes to introduce yourself in the Welcome center.
I used a 1 inch bore with the ports towards the passenger side. I went to my local NAPA and looked though the m/c book pictures and matched it from that. I don't know what the application is for.
I wouldn't use a smaller bore, it reduces the amount of fluid being pushed into the lines. Bigger is better.
Wayne
1989 Silverado
Bigger makes for a stiffer pedal.
Ed
