| | | Forums66 Topics128,162 Posts1,056,960 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2017 Posts: 13 New Guy | | New Guy Joined: Jul 2017 Posts: 13 | I posted this under big bolts, but I figured I might get a chance response here. Now that I can get my truck to move forward and backward under its own power, I noticed the truck is difficult to steer and makes a creaking sound when turning toward the right. I raised the front end off the ground and is still making the noise, but is much easier to steer and the noise isn't as loud. I pulled the plug on the top of the steering box and saw that it didn't have any fluid. I filled it full of 75-90 weight synthetic diff oil as I had it on the shelf. I have since found out that it is not as thick as was used originally, but none of it has leaked out, so I've left it in there for now. I had hoped that with the oil in the box, the creaking would subside; it hasn't. I then thought it might be coming from the bearing at the top of the steering shaft, right below the steering wheel. I pulled the wheel and removed the bearing. Turning the steering wheel still has the same creaking (only when turning right). I have also noticed that the entire steering shaft moves up and down when I turn the wheels (with & without load on it). Is this supposed to happen? Note that the dash was completely out of the truck when I bought it with nothing connected to the steering shaft. I was planning to remove the steering shaft housing since it has a bolt on clamp, but from reading on different forums it seems that it shouldn't be removed. Any suggestions on the path forward? I have ordered a new gasket kit & Steering Column Worm Trust Bearing/Adj. Lower Race 1941-1959 from Jim Carter thinking that may be the solution, but haven't pulled the box off the truck yet. Here are some pictures of the truck and steering box: https://drive.google.com/open?id=0B93HqBsSfCQnTXpkNnVKNWQ3NGchttps://drive.google.com/open?id=0B93HqBsSfCQnMS1QS0EwVkZQaE0https://drive.google.com/open?id=0B93HqBsSfCQnV254MDlaRXV6akEhttps://drive.google.com/open?id=0B93HqBsSfCQnQTl2Tzl2SzZYYjQhttps://drive.google.com/open?id=0B93HqBsSfCQnVGhpaThtcm8wbmMhttps://drive.google.com/open?id=0B93HqBsSfCQnV0c2Rlp5TU1DeGshttps://drive.google.com/open?id=0B93HqBsSfCQnVFRGZ0xiTGJMcUk | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Older trucks w/o power steering are hard to steer without the vehicle moving, so, if that is the issue, try it out when it is moving.
Ed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Seems like a creaking sound might be king pins. There should be no up and down movement of the steering shaft.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2017 Posts: 13 New Guy | | New Guy Joined: Jul 2017 Posts: 13 | Ed,
I figured that was the case, so I jacked the front end up off the ground so there was no load on the wheels and it was much easier to turn, but when turning the wheel from full left lockout to full right, it would creak.
Dave,
I had a buddy turn the wheel back and forth while I listened directly over the box and the noise is coming from inside the steering box.
Regarding the movement, I don't have a picture, but when I looked at the box from underneath, it seemed like the steering box bracket clamps the steering box to the frame, but the whole box can rotate around that clamp point. I'll try to take a picture of it tonight. | | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Hey NewGuy,
I agree with Dave, you should not be able to feel any up/down movement on the steering shaft as the lower worm gear race adjustment loads the two thrust bearings. It sounds like something is badly worn, broken or rusted inside the steering box. The upper steering bearing wont contribute to the issues you have reported. The box is not too difficult to inspect, just don't loose any of the recirculating balls or mess up the sheet metal guides that hold them all inside. If your steering box is toast I've got one that is just collecting dust, that is if you cant find more local donor.
Paul | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | | | |
