6 members (NJC, KCMongo, 59 fleet, Brian Moore, 42465967, Wally / Montana), 81 guests, and 2 robots.
Topics128,034
Posts1,055,539
Members48,425
1961 235 is in a 1953 3100. Just got it back from rebuild shop and started it up for the first time. After a few minutes I see oil all over the floor under the front of the engine. I discovered the front plate behind timing cover is bent and allowing oil to flow out between it and the block.
Oil Leak
Front Plate Bent
The rebuild shop is going to make it right but should I get him a replacement front plate or wait and see if he can straighten it back flat? It may have been bent prior to the rebuild but maybe had RTV sealing it from leaking.
I think that is pretty disgusting for a rebuild shop to put something together like that. That is a very vital support for the front of your motor. I would definitely replace it. I don't know how one could bend it like that.
1951 1 Ton Completed
Replacing that plate is a big job- - - -you need to remove the crankshaft timing gear and pull the camshaft out, plus replacing the gaskets on both sides of the plate. I'd definitely recommend going with a different plate if you can find one. Straightening is an option, but to get it flat enough to seal properly would be pretty labor-intensive and difficult. Use a piece of plate glass and a feeler gauge to check for warp if you decide to straighten it. It looks like somebody tried to pry the plate off the block with one or both of the flat head attaching screws still installed.
Just saw one today on that auction site. Might be what you need.
Ed
Was it bent before the machine shop got ahold of it?
I found a picture I took when I pulled the engine for the shop and it does not appear to be bent at that time. I think I am going to go ahead and get another front plate. Aren't all car and truck 216/235 front plates the same except for the later models need to have the front engine mount holes drilled?
pre-rebuild
Get the "new" plate and hope the rebuilder will pay for it AND fix it correctly - for free.
HrL's suggestion is, as usual, excellent.
If this costs you, you might want to post the rebuilder's name, if it is a professional shop/rebuilder.
It is a very reputable shop that builds mostly race engines. He is going to fix it for free - I would be quite upset if I had to pay! Thank you all for your responses. I couldn't do this without this site and your help.
Crusing in the Passing Lane
While you are at it, fix the timing cover do you don't have to pull the pan to remove the cover, just drill existing holes and tap to next larger size.
Ed
pre-rebuild
Yes they are the same but later models need to be drilled.
Lots more pictures
Pre 68 Dave and others would know, but I dimly recall that some 235 engines had a front plate that did not have a lip/edge where holes could be drilled?
Only late model GMC's had a plates that did not have a lip for the mount.
My Blog
thanks, Dave
thumbs_up
My Blog
I think the tech tip article is a little vague not stating to only drill the .375" and .437" holes through the steel, not into the cast iron bearing retainer. Of course, this all much easier to do when the engine is apart.
Ed
Whatever you end up doing, I would suggest that you take the matter up with the machine shop so that his guys know better the next time they work on a Stovebolt engine. Most shops have an inexperienced guy whose only job is to disassemble and throw the parts in the parts cleaner.
The guy who reassembled it is not Employee of the Month material either.
I guess that is why shops tend to give the "I don't want to do this job" price for older engines.
Carl
