| | | Forums66 Topics128,078 Posts1,056,053 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2017 Posts: 1 Moderated | | Moderated Joined: Aug 2017 Posts: 1 | My GMC 270 has what appears to be a 7/8" pulley on the crank and on the water pump. The ac delco generator has another sized pulley. As a result I am shredding belts. I am struggling to find a pulley for the generator. Any advice, contacts, links etc. would be appreciated.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | 7/8 inch? That seems a bit large. Chevy's of those years have a 5/8 inch pulley at crank, water pump and generator.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 7/8" on my 54/55 GMC 270
I think I found one, somehow, on Rockauto.com. Someone on oldGMCtrucks.com gave me a brand and part number, I think.
That person alo suggested using a 3/4" belt as a fall-back.
I'll see if I can find that info. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is the info: MPB the belt p/n is 2190637 = Napa p/n NBH2528437 $29.99, specs outside circumferenece 44.3", top width .875" With 55 amp generator p/n 2135530 = Napa p/n NBH2530467 $33.99, specs outside circumference 47.28", top width.9375. Gates TR28437 (7/8 X 44 1/4)(22mm X 1125mm) - NAPA had it Here it tis - check for it locally - Rockauto's shipping/taxes might be beatable Here are other sources. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | '54 GMC has 7/8 belts. Search at alternator/gen. shop for the correct pulley.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | '54 GMC has 7/8 belts. Search at alternator/gen. shop for the correct pulley.
Ed belts - multiple belts? Does the correct pulley have two grooves? | | | | | Joined: Apr 2010 Posts: 244 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 244 | Tom, I tried to send you a pm, but apparently you are over your topic limit. I have a complete generator with a 7/8 pulley off a '54 302. Hasn't been tested, but looks and feels runnable. Certainly rebuildable. 6 volt I'm assuming. $50+$14 shipping. Let me know. Roger Z. . | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This is not the Swap Meet.
That poster has only been here once - the time he made that one post. For good reason, he connot use the Sawp Meet until he has made a few more posts.
He could have put his email address in his profile. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If one does not need them, not have to use all belts.
Ed
