1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#12294 11/14/2003 9:16 PM
I have been working on adding power steering. I have the pump in place but it's pulley did not line up with the crank pulley by about 1/2". The pulley is only made from heavy sheet metal so I made a fixture and pressed the bushing back the 1/2". Now it wobbles about 1/32" guess my press is out of square. Is that too much? How much runout is OK for a belt driven accessory?
if it dosen't need fixed, break it
#12295 11/15/2003 12:39 AM
You should not have that much runout, it will ruin your bearing eventually. Get a new pulley and adjust the mounting brackets instead.
Paint & Body Shop moderator
