| | | Forums66 Topics128,050 Posts1,055,751 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12294 11/14/2003 9:16 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I have been working on adding power steering. I have the pump in place but it's pulley did not line up with the crank pulley by about 1/2". The pulley is only made from heavy sheet metal so I made a fixture and pressed the bushing back the 1/2". Now it wobbles about 1/32" guess my press is out of square. Is that too much? How much runout is OK for a belt driven accessory?
if it dosen't need fixed, break it
#12295 11/15/2003 12:39 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You should not have that much runout, it will ruin your bearing eventually. Get a new pulley and adjust the mounting brackets instead.
