0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | Took the 216 out and will replace with a newer 235. Is there anything I can re-use fro the 216 that I should keep before I get rid of it? Distributor, bolt ons??? | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | I wouldn't get rid of any of it until project finished (then I would hang on to it a bit longer).
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | This "get rid of it" concept. What is meant by this? It is foreign to me... Carl
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Hold on to pieces, you'd be surprised how often you get rid of something and then need it. I understand now why my Dad held onto things so long. Sell them after you're done | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Evac, If you have a complete 216 and if it ran or not, it is worth something to someone. Keep it all until the new 235 is working as expected, then sell it as a complete unit. It is getting hard and harder to find good complete engines and especially cylinder heads for both 216 and 235. A lot of the bolt ons can be upgraded, like a six or twelve volt alternator electronic ignition, pcv instead of draft tube, depends on what you prefer and have in mind for the vehicle.
Carl, I don't get it either??? Very strange concept.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I intended to rid myself of my old 216 after I pulled it to make way for a 270 I just spent $3,000 to rebuild. After installing the 270 and running it for 5 or 10 minutes I discovered the re-builder used the wrong main bearings scoring my crank and sending metal shavings throughout the engine. I had to retrieve the 216 from the junk pile out back I had dropped it in. I'm still using that old 216. I no longer throw away old truck parts that might still serve a purpose to someone. | | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | I intended to rid myself of my old 216 after I pulled it to make way for a 270 I just spent $3,000 to rebuild. After installing the 270 and running it for 5 or 10 minutes I discovered the re-builder used the wrong main bearings scoring my crank and sending metal shavings throughout the engine. I had to retrieve the 216 from the junk pile out back I had dropped it in. I'm still using that old 216. I no longer throw away old truck parts that might still serve a purpose to someone. My wife is a very encouraging person. Lately she's been "encouraging" me to reduce my spare parts inventory. Even though I know in my gut that I shouldn't throw away parts.....I've never heard an example as clear and concise as yours. That's a fantastic story. (Except for the part about the $3000 engine that was scattered in 5 minutes). My retort was something lame like: "they aren't making this stuff anymore." To which she replied, "there's a reason....it's junk." She's not just encouraging....she's also clever. I robbed an exhaust manifold off spare engine a few months ago when I found my heat riser was hopelessly stuck. That whole engine cost probably 1/3 of what folks are asking on EBay for just the manifold.
1951 3100
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | JW, right, wrong, or indifferent, your wife deserves full credit for her retort. Was it delivered confidently, without hesitation? Mine just yells incoherently without making any sense whatsoever. I, of course am still "wrong" nonetheless. Carl
| | | | | Joined: Jan 2014 Posts: 3,684 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,684 | JW, right, wrong, or indifferent, your wife deserves full credit for her retort. Was it delivered confidently, without hesitation? Mine just yells incoherently without making any sense whatsoever. I, of course am still "wrong" nonetheless. Carl Yes, it was stone cold perfect. Delivery, timing....nailed it.
1951 3100
