0 members (), 142 guests, and 2 robots.
Topics128,132
Posts1,056,730
Members48,454
#1229201 08/09/2017 3:50 AM
Not sure what to look for with this. Had truck out, was inching backwards as I put my clutch in, As I let off the clutch in forward gear, I heard a clang from the rear axle. Now it wont move. The driveshaft spins into the rear axle, took pumpkin cover off and ring and pinion are moving with drive shaft. No broken parts or large parts of metal visible. When truck is in gear, I have movement on the right side with the ring and pinion but the left stays stationary. Anything obvious I can check ? Is this a symptom of a broken axle shaft ? I saw the axle shaft ends and they appeared ok, but didnt pull them out. Any help would be appreciated.
Does sound like a broken axle shaft. Pull right side and see where the break is.
Right side broken at the splines... 3652294 is the part number. Just need to find one.
Riding in the Passing Lane
What year are we talking about?
1972 Chevy c10 Cheyenne Super
42, a 42-46 should fit. The is the longer axle on right side
' Offline
Call Dan's GM Obsolete in Chinook, Montana
phone: 406 - 357 - 2615
He may have one in stock .
Here's the axle being sold on ebay by Bruce Bugay in Virginia .
http://i669.photobucket.com/albums/vv57/glp0329/axle%203652294/3652294_zpsietcwqoe.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
