| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I can't seem to get it through my pea brain how the odometer wheels go together in relation to each other. I have read the tech tips but still have the question. One side has the gear teeth all around and the other just has one place where the gear catches. Can someone tell me how you place them so when one goes around and flips the next one? Thanks.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I believe the geared sides all go to the left [later years anyway] - the single tab sides to the right, to catch the next higher number - numbers all right side up at any rate, and the "plates" between
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks Bill. So I would set them all to zero and the single tabs are only engaged when it is time for that wheel to turn? Seems like they would change by vibration before that time.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you get it all together right, the wheels can't possibly move without being driven, no vibration involved - the single tabs are like a one tooth gear, when the lower number goes past 9 the tab pushes the next wheel one notch [one number], and if that wheel was on 9 and moves to zero, its tab pushes the next wheel one number higher .... you can set them all anywhere, but you need to have them all in correctly with the plates between properly, otherwise they might be advancing at the wrong time - if you've replaced the numbers without noting the correct positions of the wheels there's a good chance of problems  Bill | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'll check to see if I replaced the numbers correctly. So all the single tabs will be engages with the small gear that is in each plate?
Dennis
40 Chevy 1/2 ton
