0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
Hey guys, I've read every thread on wheels on this forum and I'm still trying to decide which way to go. (I'm in the same boat as many of you).
Can someone tell me if these are the wheels that should be replaced asap, or if I can safely and comfortably run with these.
Here is the truck that I'll be fixing up, and said wheels.
https://goo.gl/photos/bYVT4sNyygsydYQCA
https://goo.gl/photos/1JVV6p8hbZc2e9oB8
https://goo.gl/photos/DZoBxoV3u4LgddRH9
https://goo.gl/photos/8TVJiAwTzLRPRufF6
Thanks!
-Nick
Offline
Offline
A split rim, technically, is one that is a 2 piece rim that separates in the center. What you have is a lock ring style rim. Tire shops won't touch a split rim, but they will mount lock ring rims as long as the condition of the rim is good. many won't trust either style, but solid rims are hard to come by, unless, of course, you can afford them!
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
Nick,
If you can get close-up photos of those wheels, you/we should be able to if you have lock-ring style rim.
24601
Read Grigg's Tech Tip on the subject -- Good photos are included that will help you identify those rims.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks guys, I'll get some better pics of the wheels. Thanks for the article. Very helpful.
From an aftermarket perspective, what brand/model number of wheels bolt on with no spacers? I've looked all over, but even awful looking modern wheels don't seem to come in the necessary size off the shelf.
-Nick
Here are some better pics of the wheels...
https://goo.gl/photos/Zgt7NFFumA1QFCDn6
https://goo.gl/photos/CpA9Xu3hHs7GWgod9
https://goo.gl/photos/PYLdv9GZGLzXzAV59
I still can't quite tell if I should be able to run these or if I need to look for something else. I'd like to run these if possible.
Nick
Crusing in the Passing Lane
Those look like 18's, modern replacement 19.5's are a good replacement.
Ed
Offline
Offline
I happen to have a set of 19.5's... :-)
Elderly Iron
That design of wheel has an edge-locking full circle ring with a very narrow locking surface that is susceptible to rust damage. They're not as dangerous as the center-split "widowmaker" rims. I ran them on a 59 3800 and it was difficult to get the lock rings to seat properly during inflation. If you can find a good set of 19.5" tubeless tires and rims, it would be a better choice than trying to run the 18" tube type tires. That size rim was used quite often on step-van type 1-ton chassis bread trucks. If there's a bakery near you check to see if maybe they have a stockpile of old wheels stashed away.
Pm Sent.
-Nick
Glad y'all are making connections and solving problems.
Please keep buying and selling confined to PMs and in the Swap Meet section.
Moderated by  Dusty53
