1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | A split rim, technically, is one that is a 2 piece rim that separates in the center. What you have is a lock ring style rim. Tire shops won't touch a split rim, but they will mount lock ring rims as long as the condition of the rim is good. many won't trust either style, but solid rims are hard to come by, unless, of course, you can afford them! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Nick,
If you can get close-up photos of those wheels, you/we should be able to if you have lock-ring style rim. | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Read Grigg's Tech Tip on the subject -- Good photos are included that will help you identify those rims.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2010 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 39 | Thanks guys, I'll get some better pics of the wheels. Thanks for the article. Very helpful.
From an aftermarket perspective, what brand/model number of wheels bolt on with no spacers? I've looked all over, but even awful looking modern wheels don't seem to come in the necessary size off the shelf.
-Nick | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Those look like 18's, modern replacement 19.5's are a good replacement.
Ed
| | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | I happen to have a set of 19.5's... :-) | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | That design of wheel has an edge-locking full circle ring with a very narrow locking surface that is susceptible to rust damage. They're not as dangerous as the center-split "widowmaker" rims. I ran them on a 59 3800 and it was difficult to get the lock rings to seat properly during inflation. If you can find a good set of 19.5" tubeless tires and rims, it would be a better choice than trying to run the 18" tube type tires. That size rim was used quite often on step-van type 1-ton chassis bread trucks. If there's a bakery near you check to see if maybe they have a stockpile of old wheels stashed away. Jerry
| | | | | Joined: Jul 2010 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 39 | I happen to have a set of 19.5's... :-) Pm Sent. -Nick | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Glad y'all are making connections and solving problems. Please keep buying and selling confined to PMs and in the Swap Meet section. | | |
