| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Has anyone used a hydra-matic shift column connected to a turbo 400?Truck is 1953 gmc with a 350 and turbo 400. I know Speedway sells a kit just wondering if somebody used that or how they did it. Thanks Steve. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | If I had one when I built my '49 with a TH400, it would have saved me a bunch of time. I modified the 3 on the tree shifter and box and custom made an indicator dial with little brass letters in the same font as the speaker grille letters on a polished stainless steel backing.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That sounds cool. It would be neat to see a picture of that. | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | The linkage could probably be adapted to the TH 400 shift quadrant, but the gear positions would be all wrong. The Dual Range didn't have a Park position, and Reverse was all the way to the right on the indicator. Jerry
| | | | | Joined: Mar 2011 Posts: 85 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 85 | Thanks for the reply. I have seen it done on trucks at some shows but never got to ask the owners about it. Again thanks. Steve | | |
