6 members (Jon G, Hotrod Lincoln, rfs56trk, BC59, Robert Crandall, Gray_Ghost), 94 guests, and 1 robot.
Topics128,122
Posts1,056,331
Members48,439
#1226882 07/24/2017 4:02 PM
Its been a while since I've posted on here. I have a 59 Apache with a 283. Original engine, tranny and clutch, although tranny and clutch were rebuilt about 5 years ago. Recently I have been hearing a squeaking noise whenever I engage the clutch.Curiously, the noise occurs as I am releasing the pedal, not when I push it down. I got it up on the lift with my lovely assistant in the cab and asked her to push the pedal so I could try to localize the noise. As best as I could tell it was coming from inside the clutch housing, inside where the clutch fork enters. Is this anything that is serious? Any suggestions on how to stop the squeak? Thanks, as always.
1956 Apache
1959 Apache
1966 DeVille
Throw out bearing. Not complicated to replace just time consuming. Having a lift makes the job easier.🛠
Thank you very much!
1956 Apache
1959 Apache
1966 DeVille
is it squeaking with the engine off? if it is I would suspect the linkage might need some lube. a bad throwout bearing is more likely to present itself more readily when the mechanism is turning.
Check to see if the ball and socket of the clutch fork/bell housing are in good shape.They never seem to get greased.
