| | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | Its been a while since I've posted on here. I have a 59 Apache with a 283. Original engine, tranny and clutch, although tranny and clutch were rebuilt about 5 years ago. Recently I have been hearing a squeaking noise whenever I engage the clutch.Curiously, the noise occurs as I am releasing the pedal, not when I push it down. I got it up on the lift with my lovely assistant in the cab and asked her to push the pedal so I could try to localize the noise. As best as I could tell it was coming from inside the clutch housing, inside where the clutch fork enters. Is this anything that is serious? Any suggestions on how to stop the squeak? Thanks, as always.
1956 Apache 1959 Apache 1966 DeVille
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Throw out bearing. Not complicated to replace just time consuming. Having a lift makes the job easier.ðŸ›
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | is it squeaking with the engine off? if it is I would suspect the linkage might need some lube. a bad throwout bearing is more likely to present itself more readily when the mechanism is turning. | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Check to see if the ball and socket of the clutch fork/bell housing are in good shape.They never seem to get greased.
