3 members (Otto Skorzeny, gswbbc, joe apple), 165 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1226292 07/19/2017 10:08 PM
I have a coolant leak at the head to block.Replaced the head gasket twice still ozzes out.Will one of the additives on the market work or will they plug up something? I have heard good and bad on these products(barrs al etc.)Any thoughts will be a help.
You need to pull the head and have it checked for warpage at a machine shop. They can fix it. While the head is off, check the condition of the block deck surface.
Don't use any additive unless absolutely necessary (like, to get home), and then flush it out.
Riding in the Passing Lane
I've used Bars-Leaks for years on small leaks like that & it has always worked & never clogged any thing up. Follow directions. Make sure the system is warmed up & circulating.
George
1972 Chevy c10 Cheyenne Super
The head was off and surfaced at a reliable machine shop.The block was surfaced when it was rebuilt three years ago(500 miles ago)
At this point trying Bars Leak won't hurt a thing. If it works great, if not, well, your going to have to tear it down.🛠
To recap:
The head and block was surfaced.
You have replaced the head gasket twice, because of head gasket leaks.
Did the leak occur right away? Exactly where is it leaking?
What year engine do you have?
What engine work was performed at the time before the first head gasket leak occurred?
What brand of head gasket did you use?
What torque setting did you use on the head bolts? Did you tighten them in sequence at half the final spec before you tightened them to the final specs?
Did you try to re-torque the bolts after engine warmup?
I had a 235 full pressure engine which seeped oil from the head gasket on the distributor side of the engine which was corrected by re-torquing the head bolts after the engine reached operating temperature.
There has to be a logical reason for why you are having this problem. Adding stop leak may fix the leak, but it will not solve the mystery. I like solving mysteries. It helps avoiding similar problems in the future.
Carl
Crusing in the Passing Lane
Sodium Silicate is an excellent 'get home' remedy, however my most recent experience indicates the use of antifreeze disables it's effectiveness.
Ed
