2 members (2-Ton, farmallb),
62
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Hey all, I've got an issue where the chrome piece above the grill on my '40 Chev dives low at the front center instead of being parallel to the top bar of the grill. I don't see how to adjust that up. Any clues welcome.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Come on cleaver people. I just know there is something simple to this, but I'm too simple to figure it out.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Are you sure it's the script dipping down , and not the grill bars out of line?? | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Dusty, the grill bars are nice and straight. I put a yard stick across the script bottom touching the painted sheet metal. Getting back and eyeballing it, it looks like the script dips down about 3/8". I'm waiting for paint to dry on some small parts so will look closer at it today to try to see where I can make some corrections.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Here's what I found today. I should have mentioned the grill I'm using is a reproduction. Another case of reproduction not the same as OEM. Anyway when I laid the repro alongside an original, it was obvious. The OEM grill bars slope toward the ground when installed. The repro does not. Each bar is welded at the out frame as original. The first thing I did to correct the shape was to screw the grill to the table. Then clamped a stack of 2 x 6's to the table about 8" gap from the grill. I've got a small scissor jack that I then put against the 2 x 6's and the center bar and forced the grill into position. I've got one remaining issue for tomorrow. I have to resolve why I can fit the grill on the truck except that the upper screw hole on each side does not match up to the grill.
So Dusty, you were right on.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks for the update Dennis , I had wondered about that after seeing some pics where the droopy top bar was a problem. | | |
