| | | Forums66 Topics128,004 Posts1,055,252 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | On a 1958 Step Side or Fleetside 1/2 ton where does the grounding wire for the turn signal actually attach. This is the single wire that comes to the bottom of the steering column. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Why would a turn signal switch need a ground? It simply routes voltage to the front and rear bulbs and puts them in series with a flasher. The ground happens at the body sheet metal downstream from the light filaments. If there is a ground wire in the switch harness for some unknown reason, it can be attached anywhere under the dash to the steering column or any other part of the body metal. Jerry
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Why would a turn signal switch need a ground? If it has a pilot light the signal switch has to be grounded. IM Not familiar with the 58, or the single wire comming out the column. ... | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | By 58 the indicator lights were built into the dash cluster. My 59 Burb has the same V-shaped dash panel, and it has turn indicators built in. Jerry
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I have a 59 with after market turn indicator. The only wire that comes out of the steering column is for the horn. I believe it is dark brown.
It may be different on a 58 with factory turn signals don't know.
Tommy 59 apache 1/2t 261 short stepside | | |
