0 members (), 118 guests, and 3 robots.
Topics128,186
Posts1,057,320
Members48,469
#1226257 07/19/2017 4:22 PM
On a 1958 Step Side or Fleetside 1/2 ton where does the grounding wire for the turn signal actually attach. This is the single wire that comes to the bottom of the steering column.
GMCAMARO #1226259 07/19/2017 4:31 PM
Why would a turn signal switch need a ground? It simply routes voltage to the front and rear bulbs and puts them in series with a flasher. The ground happens at the body sheet metal downstream from the light filaments. If there is a ground wire in the switch harness for some unknown reason, it can be attached anywhere under the dash to the steering column or any other part of the body metal.
If it has a pilot light the signal switch has to be grounded.
IM Not familiar with the 58, or the single wire comming out the column. ...
GMCAMARO #1226264 07/19/2017 5:17 PM
By 58 the indicator lights were built into the dash cluster. My 59 Burb has the same V-shaped dash panel, and it has turn indicators built in.
GMCAMARO #1226320 07/20/2017 1:44 AM
I have a 59 with after market turn indicator. The only wire that comes out of the steering column is for the horn. I believe it is dark brown.
It may be different on a 58 with factory turn signals don't know.
Tommy
59 apache 1/2t
261 short stepside
