8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle), 106 guests, and 2 robots.
Topics128,179
Posts1,057,068
Members48,460
8
8 Offline
I would like to remove my rear spring pins and check them and the shackle for damage. I am reading in the manual that you need a J-1436 Axle shaft bearing and oil seal remover, as well as J-1436-9 Shackle pin remover adapter. I searched the archives and only found information pertaining to the smaller trucks with the cinch thread not bolt clevis and plain bushing that the big bolts have. One member mentioned a hole through the frame where you could use a drift to get them out. The J-1436 tool looks little like a dent puller/slide hammer, has anyone made a tool to get them out?
Curt
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
3B Offline
Hy 801curt, there probably is an access hole behind the pin in the frame that you can use to drive the pin out with a large punch. I made up a tool to pull the pins out using a threaded rod which I re-threaded to 1/8" pipe thread on the end which screws into the grease fitting hole once it is removed, a piece of pipe/tubing a little longer than the pin and a heavy washer and a nut to thread down the rod has removed every one I have tried so far. You should take the tension/weight off of the pin before you attempt to pull or drive it out, hope that helps.
8
8 Offline
Thank You so much 3B! How did you make your threaded rod? Bar stock and a die? Or a length of all thread and a die? I do appreciate the reminder of removing tension.
Curt
Curt Warren
Salt Lake City
I've has success getting them out with a threaded adapter for the grease fitting on the end of a slide hammer.
3B Offline
Hy 801curt, I used a piece of 7/16" n.f. threaded rod and machined it down and cut the 1/8" pipe thread into it with a die, hope that helps.
8
8 Offline
Thank You 3B, JIm was it a 1/8 npt then the other side screwed on to your slide hammer shaft?
Curt Warren
Salt Lake City
