Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (baldeagle, Peggy M, 55shaker), 30 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
#1225933 07/17/2017 7:57 PM
So I am in the middle of changing out my motor mounts and noticing while changing the front mount there appears to be
a very thick (1/8") washers under the outer bolts. They appear to be shims a nd also seem to have been there for a very long time
as they have worn circular divots in the frame. I have seen pictures of other owners 235's with these washers.
Can anyone offer feedback regarding motor mount shims and if they are supposed to be there.
54 1/2 ton PU 235
radiator frame alignment shims - "anti-squeak spacers under radiator core support" (see link below)
This allows up-down adjustment of front-end sheet metal - to help a little with hood-to-fender alignment?
Installation as an Assembly - step #3
The washers on the outer two bolts between the engine mount and crossmember are correct.
We have had discussions here as to what they are for, but no GM documentation.
My Blog
I just recently replaced the front motor mount on my 1954 3/4 ton truck and yes the "thick washers" were under each of the two outside bolts.
This washer is shown in the Factory Assembly Manual , section 6, Sheet 12.00, 365685 special washer.
In the 1929-1954 Master Parts and Accessories Catalog they are shown under Group .002, Washer, Front Mounting, 2x , 3/8 ID x 1 1/4 OD , part number 365685 . The thickness is not given and I now wish I had measured the ones on my truck before I reassembled the front motor mount. Hope this information helps.
Ron - - Dusty53
1954 Chevy 3604
The location of the thick washers is difficult to see in the reproduction FAM.
I installed the thick washers incorrectly when I installed my front mount in my '54 3104. This link recaps the parts that I used. The link also has a link to a post in which Denny Graham discussed the CORRECT way to install the thick washers.
https://www.stovebolt.com/ubbthread...610/re-front-motor-mount.html#Post974610
This link is the full description of my installation.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=825049#Post825049
The photos are stored on PhotoBucket, so they won't display because of PhotoBucket's new 3rd party sharing restrictions. Contact me and I will send any of the photos that you need. Email address in my signature line.
- Lonnie
- Lonnie
My '54 3104
