0 members (), 114 guests, and 1 robot.
Topics128,105
Posts1,056,541
Members48,448
Stovebolt,
Simple stuff.
Not sure what the valve in the exhaust manifold is called, or what is does, but I would like to know more. I thought it might choke the exhaust until things got warm and then open to the exhaust pipes. Does it effect starting or engine performance when cold?
HB
~ HB
1962 Chevrolet C10
1962 Suburban
Riding in the Passing Lane
You are referring to the heat riser valve. It closes when cold & partially blocks the exhaust sending some of it through the passages in the intake manifold. This warms the incoming fuel/air mixture & gives better running & better gas mileage. As the engine warms up the thermostatic spring relaces & the valve opens. The butterfly is also mounted off center so it also opens under hard acceleration. I hope that explains it.
George
1972 Chevy c10 Cheyenne Super
Hambone,
2x what George said...great explanation!
If you need one here's a link...
https://www.summitracing.com/parts/...a2D3MYr2SvqjOUbIi3IVPyH3o60aArvvEALw_wcB
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks guys. That answers it.
~ HB
1962 Chevrolet C10
1962 Suburban
