5 members (Bill Marlow, TUTS 59, Wally / Montana, Shade Baby, 1 invisible), 80 guests, and 4 robots.
Topics128,132
Posts1,056,385
Members48,441
Is there supposed to be some kind of rubber bumper between the stomp starter assembly and the firewall? When my starter pedal returns to the "off" position via the spring, it hits the cab firewall...
~ Dave
Don't believe a bumper was stock however it would be an easy retrofit since there is approximately 1/2" clearance before the arm contacts the starter switch.
Ed
Sounds like the cab mounts have sagged.
Jim,
The cab mounts are all brand new, and I just mounted my cab, however, I have not yet adjusted the cab per the manual. The thing is, if the cab position needs to move, it will be the rear end coming up, which will makes things even worse as far as firewall clearance...we'll see.
Ed, yeah, I didn't see anything in the manual. I'm thinking that the lever that goes into the starter is worn on the side that bottoms out when the gear is retracted... if adjusting the cab doesn't do the trick, then I'll have to pull the lever out to take a look at it. There is plenty of clearance between the arm and the switch, however, the starter gear begins to slide out on the shaft the instant the pedal is depressed- I sure wouldn't want to get the gear too close to the flywheel ring gear teeth! I could always shorted the link between the bell crank and the lever?
Thanks guys.
~ Dave
