| | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 23 | Can someone help? I have a 1950 3100 with stock 6.50x16 tires. Can I fit a modern day radial on there without a tube? Or must I have a radial type tube to go with it? I can't seem to find a straight answer in the forums. It would be save me some money and increase drivability if I could go with the modern tire and no tube, however other than looks are their drawbacks? Thanks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If your wheels will hold air without tubes, mount the radials tubeless. If the wheels do not hold air use tubes.
I have a set of LT215/85R16 blackwalls with and without tubes. "other than looks . . " They look like originals.
The ones with tubes have been on my garage-parked Suburban for over 13 years (but, only have about 11K miles on them).
You have to play with the PSI - high enough for easy steering, but not so low that you wander at high speeds. I think mine are between 40-45psi. | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | I sand blasted the rims and put on black epoxy paint--49-3100 ...no need for tubes.Original 6 clip wheels all 5--Bill | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Rims designed for tubes do not have the safety bead lock hump. This hump keeps the tire on the rim when air pressure is lost.
https://www.google.com/search?q=safety+bead+wheel&client=safari&hl=en-us&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi1soH7m4_VAhUBxYMKHeU5CFoQ_AUICigC&biw=1024&bih=649#imgrc=shEKnaMK9eLvZM:
