4 members (Gray_Ghost, BillCollins, Still At It, 1 invisible), 134 guests, and 2 robots.
Topics128,078
Posts1,056,054
Members48,433
#1225278 07/13/2017 2:33 AM
Back to my 52 3 speed. When would be the best time to torque the u joint ball cover bolts. Jackstands under the frame, or weight on wheels, or does it matter? 1/2 ton 3 speed torque tube.
TommyJ
Any time, TommyJ,
No need to over torque (15-25 lbs would be plently).
If you have leaks there (VERY common), the best bet (and it is a painful one) is to do the cover/seal adjustent procedure described in the Transmission section (I think) in the Shop Manual.
