| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 33 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 33 | Back to my 52 3 speed. When would be the best time to torque the u joint ball cover bolts. Jackstands under the frame, or weight on wheels, or does it matter? 1/2 ton 3 speed torque tube.
TommyJ | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Any time, TommyJ,
No need to over torque (15-25 lbs would be plently).
If you have leaks there (VERY common), the best bet (and it is a painful one) is to do the cover/seal adjustent procedure described in the Transmission section (I think) in the Shop Manual. | | |
