| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 31 | Have 248 in a 55 1st series 100, motor had antifreeze in the oil. Took head to machine shop, they said it is cracked by head bolt holes. Could not find a person to bake and weld the cast iron. Do any other heads swap? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to also join oldGMCtrucks.com discussion board.
Some of their members are also here.
Since you know what you need (can use), place a Want Ad here and at oldGMCttrucks.com
Good luck. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | There are 4 different types of head: 1. Large or small intake port (yours is almost certainly "small", intake about 1-1/2") 2. Open or closed combustion chamber; unless you're going to replace the pistons you must use the type head you have since its shape depends on the piston dome shape. | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Check with a company called "Diesel Cast Welding". They repair big commercial engine blocks and heads, but I'm not sure if they also work on passenger car and light truck equipment. They're expensive, but very good at what they do. http://dieselcastwelding.com/Jerry
| | | | | Joined: Oct 2015 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 31 | Ok, thanks for the input and leads. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | from a friend on oldGMCtrucks.com, who knows: I saw the post on Stovebolt from the guy looking for a head for his 248.
Tell him to look here,
http://www.patricksantiquecars.com/chevy-gmc-auto-parts.html#chevy15
He should read the last four digits of the casting number on his head, my guess is that he needs a 4819 head, There are no other heads that will swap to a 248 other than the cracked one he already has...
I have a couple of heads, but I need to know which one he needs.
Happy Motoring,When you know your head casting code, and, if you want to contact my friend, please send me a PM with your phone number. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | You could also try Larrowe and sons, they used to be in Sandy oregon, but I think they are in Portland now. Either way a google search should bring them up.
| | | | | Joined: Oct 2015 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 31 | I called Patrick and he is looking and will call back. http://www.patricksantiquecars.com/chevy-gmc-auto-parts.html#chevy15 Larrowe passed away and his son is doing business as jjinline.com, he has one option for me. I have a call into diesel cast welding. Thanks for the help. | | |
