0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1225141 07/12/2017 2:35 PM
Have 248 in a 55 1st series 100, motor had antifreeze in the oil. Took head to machine shop, they said it is cracked by head bolt holes. Could not find a person to bake and weld the cast iron. Do any other heads swap?
mike383940 #1225143 07/12/2017 2:43 PM
You might want to also join oldGMCtrucks.com discussion board.
Some of their members are also here.
Since you know what you need (can use), place a Want Ad here and at oldGMCttrucks.com
Good luck.
mike383940 #1225148 07/12/2017 3:07 PM
There are 4 different types of head:
1. Large or small intake port (yours is almost certainly "small", intake about 1-1/2")
2. Open or closed combustion chamber; unless you're going to replace the pistons you must use the type head you have since its shape depends on the piston dome shape.
mike383940 #1225218 07/12/2017 11:08 PM
H Online: Content
Check with a company called "Diesel Cast Welding". They repair big commercial engine blocks and heads, but I'm not sure if they also work on passenger car and light truck equipment. They're expensive, but very good at what they do.
http://dieselcastwelding.com/
mike383940 #1225360 07/13/2017 8:33 PM
Ok, thanks for the input and leads.
mike383940 #1225487 07/14/2017 2:25 PM
from a friend on oldGMCtrucks.com, who knows:
I saw the post on Stovebolt from the guy looking for a head for his 248.
Tell him to look here,
http://www.patricksantiquecars.com/chevy-gmc-auto-parts.html#chevy15
He should read the last four digits of the casting number on his head, my guess is that he needs a 4819 head, There are no other heads that will swap to a 248 other than the cracked one he already has...
I have a couple of heads, but I need to know which one he needs.
Happy Motoring,
When you know your head casting code, and, if you want to contact my friend, please send me a PM with your phone number.
mike383940 #1225632 07/15/2017 2:01 PM
You could also try Larrowe and sons, they used to be in Sandy oregon, but I think they are in Portland now. Either way a google search should bring them up.
mike383940 #1225919 07/17/2017 6:06 PM
I called Patrick and he is looking and will call back. http://www.patricksantiquecars.com/chevy-gmc-auto-parts.html#chevy15
Larrowe passed away and his son is doing business as jjinline.com, he has one option for me.
I have a call into diesel cast welding. Thanks for the help.
