4 members (TexasJim50, RLB, GIJOE298, Otto Skorzeny), 61 guests, and 2 robots.
Topics128,154
Posts1,056,851
Members48,456
#1224713 07/10/2017 5:29 AM
do you guys know if the standard body mount bushings available for 1/2 ton trucks are the same as a big bolt. i am looking at the kits and i don't know if it is right. i can only see the rear cab mounts on my truck and they have a rubber donut shaped bushing between the cab and the mount and one below the mount. this is one link but i can't tell what's in the bag
jim carter cab mounts
this is a link from eBay that clearly shows the parts.
ebay
1959 Chevy 8500 - Spartan 80
366 BBC
Gene,
Your truck should have very thick rubber cab mounts that are about 1-1/2" thick. There are 4 bushings needed, two on each side, they sandwich the frame cab mount allowing both up and down motion as the frame twists under heavy load.
I got a hunk of scrap rubber from a local rubber supply company that they sell for the bottom edge of snow plow blades. Turns out it was the exact thickness needed and I used a hole saw to cut the round bushings out.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
thanks, mike. what is under the front of the cab?
366 BBC
Gene,
I've never taken a 58/59 cab off of a frame, but the 55-57 cabs ALL have the same Anti-Squeak Rubber Pad about 2" square and 1/16" thick. I assume you would have the same.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
