| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | do you guys know if the standard body mount bushings available for 1/2 ton trucks are the same as a big bolt. i am looking at the kits and i don't know if it is right. i can only see the rear cab mounts on my truck and they have a rubber donut shaped bushing between the cab and the mount and one below the mount. this is one link but i can't tell what's in the bag jim carter cab mountsthis is a link from eBay that clearly shows the parts. ebay
1959 Chevy 8500 - Spartan 80 366 BBC
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Gene, Your truck should have very thick rubber cab mounts that are about 1-1/2" thick. There are 4 bushings needed, two on each side, they sandwich the frame cab mount allowing both up and down motion as the frame twists under heavy load. I got a hunk of scrap rubber from a local rubber supply company that they sell for the bottom edge of snow plow blades. Turns out it was the exact thickness needed and I used a hole saw to cut the round bushings out. Mike B  | | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | thanks, mike. what is under the front of the cab?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Gene, I've never taken a 58/59 cab off of a frame, but the 55-57 cabs ALL have the same Anti-Squeak Rubber Pad about 2" square and 1/16" thick. I assume you would have the same. Mike B  | | |
