3 members (Dennys28, Southerntruck, KEVINSKI), 82 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
#1224657 07/09/2017 11:46 PM
In the process of cleaning gas tank and repairing or replacing sending unit on my 1 1/2 ton Loadmaster. Looking at filler neck and trying to determine if it is wise to try to remove neck where it appears to be bolted on. It would greatly improve my ability to inspect, clean and repair. The question is, if the flange going to come off easy are there gasket parts for it and if it does not want to come off should I just leave it alone? Has anyone had experience with this gas tank model including the filler neck? Pictures of tank and a closeup of the neck are in my photo album. 48 Loadmaster Photo Album
Roger Burgoyne Member # 42,919
1948 Chevrolet 1-1/2 Ton Loadmaster w/Dump
Terre de Bourgogne Llama Ranch, Arizona
8
8 Offline
I never messed with the filler neck on my '48 1.5ton. I was able to see everything I needed with the panel over the float removed.
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
I have a similar tank on my 1 Ton Flatbed Dually that had a leak at the filler neck connection to the tank. Although it looked to be bolted on it was in fact bolted and soldered on. I took to a good old fashioned radiator shop and they were able to clean the tank and fit the filler neck back on. Seemed routine to them!
Thanks Curt, I will give that a try before anything more.
Thanks Jim,
I suspected there might be solder involved. I'll try and take a peak via the sending unit if it comes off easy. Then decide about a radiator shop. Appreciate your input.
Sir Searchalot
Sir Searchalot
Making a new gasket would be very easy.
Crusing in the Passing Lane
If one fills the tank with water, can use torch to weld or solder.
Ed
