4 members (Woodcmiami, Sjm, Steelonsteel, Hotrod Lincoln), 122 guests, and 6 robots.
Topics128,266
Posts1,058,385
Members48,485
#1224422 07/08/2017 4:49 PM
58GMC 1/2ton truck; 6cylinder GMC302. Can't find info in maintenance manual where the hoses go.
Water pump and thermostat housings hoses to the two connections on the firewall?
Thanks in advance,
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
Riding in the Passing Lane
The one under the therm. is the pressure hose. It will go to the lowest connection on the heater. The higher outlet on the heater is the return & goes to the water pump.. Somewhere around that era they started using 5/8 hoses on the pressure side & 3/4 on the return. If that's the case it is obvious which one goes where. If there is a valve in the circuit the pressure side will go to the valve first.
1972 Chevy c10 Cheyenne Super
Both of them are side by side under the battery tray, on the firewall.I hooked the one closest to the inner fender to the water pump; and the one closest to the motor to the thermostat housing.But not sure...
Danny
It' will work fine.
