0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | 58GMC 1/2ton truck; 6cylinder GMC302. Can't find info in maintenance manual where the hoses go. Water pump and thermostat housings hoses to the two connections on the firewall?
Thanks in advance,
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The one under the therm. is the pressure hose. It will go to the lowest connection on the heater. The higher outlet on the heater is the return & goes to the water pump.. Somewhere around that era they started using 5/8 hoses on the pressure side & 3/4 on the return. If that's the case it is obvious which one goes where. If there is a valve in the circuit the pressure side will go to the valve first. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Both of them are side by side under the battery tray, on the firewall.I hooked the one closest to the inner fender to the water pump; and the one closest to the motor to the thermostat housing.But not sure...
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
