8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Some time ago, I acquired paint no.s for the interior of my 52. Both PPG. Can anyone verify these numbers? My paint guy has shown me a sample panel he painted. What I saw was a deep copper bronze that had a very fine metal flake in it. Can this be right? I don't have anyone near me to compare color to. Please help before the deed is done. PPG DDL3613 or DCC5558 | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The color sounds pretty close. I haven't seen an original in good enough shape to tell if it originally had metal flake or not. You might want to contact Bob Adler (you can do a forum search for his contact info). He is the guru of all things original and factory about AD's.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You can buy correct brown metallic interior paint at: www.chevsofthe40s.com I used an interior BMW paint that was the same. | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | So you're saying it IS a brownish METALLIC. Is that what you're saying? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dave, could you share the paint mfg and number with us for that interior paint? Tks Denny G
Denny G Sandwich, IL
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | The interior color for the 53 Chevy Truck is "Sheen Gray Metalic". I was always under the impression that the 52 and 53 interiors were the same. I do know for sure the window knobs, seat covers, door panels and headliner were the same color for 52 and 53, "maroon". | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The original Dupont code for Sheen Gray Metallic (1953) is: 202-81407
The original Ditzler (PPG) code (1953) is: 31104 | | |
