2 members (Steveoreno, 1 invisible),
126
Mod | | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Since I tore my 53 3100 apart over 16 years ago, I am asking for help with fasteners. I would like to use the original type screws and bolts. No doubt, a number of you will know what type fastener, were used for the Window Regulator, Door Lock Remote Control, Vent Window Assembly and the Glass Run Guide Channel. Were they Clutch Head, or Phillips Head screws? Or, a combination of both?
Happy Independence Day to you all.
Thank you in advance for your help, advice and guidance.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Clutch heads with internal star washers for the regulators, door lock remotes. I believe the vent windows take hex head bolts. Glass run channel guides used clutch head screws at the bottom. I don't know about the top screws. I have only seen Phillips head screws there, but I am sure that I wasn't the first one to remove/replace those.
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Thanks Carl. That was my very vague recollection of what came out of there. If I would have any idea the length of time it would be, when I got ready to replace them, I would have paid more attention. Probably not the first guy to say that, nor the last.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Jan 2013 Posts: 2,239 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,239 | I went to my local lowes and purchased new bolts for mine since they are all covered up (can't remember sizes). I pretty sure that the channel guides at the top of the door and internal window frame cover use a #6, I purchased extra bolts. I can send you the size once I get home. For some reason, I am thinking it was mainly 7/16 x 20 but I can confirm if no one else chimes in. | | | | | Joined: Jan 2013 Posts: 2,239 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,239 | Ok, the hex head size was what I was thinking. After looking, the bolts on my door were 5/16-18 (vent window to door inside door) and 1/4-20 (external lower vent window to door and all door latches, handles, etc.). Sorry, I don't have any extra bolts that held the channel inside the door. The upper channel (flexible) and the top of the vent window was a #6 bolt (if it was loose, I used a #8 to secure).
I hope that this helps a little bit. I just put my doors together within the last month. If you need any other door bolt size, just ask.
FYI, this was on a 51 3100.
Chris | | |
