3 members (Peggy M, FAST55, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,050
Posts1,055,759
#1223625 07/03/2017 12:52 AM
I just finished bleeding my 49 half ton's brakes and when I went to put the fill plug back into the master cylinder, I noticed that a thin "gasket"(?) was dangling from the plug. I am guessing a gasket or some sort of seal is needed to keep the system air tight, but where can these be found? After looking at the usual Chevy truck online part sites I found MC rebuild kits that include a fill plug/cap and an o-ring that looks like it might go into the fill plug/cap, but I have not found just the gasket or o-ring.
Is a seal necessary, or will keeping the plug tight be enough of a seal?
Weeellllllll, it might be OK without a gasket. The cork casket on my 51 is broke in one place and I've been babying it for a couple of years. When it totally fails I plan to make a replacement from cardboard (as from a shoe box or such, not brown cardboard). A ball peen hammer and a couple appropriate sized sockets are all that's required.
RonR
1970 340 Duster
1964 CJ5
A GOOD auto parts store will have a Dorman section. Orange and Black steel cabinets with every fitting,washer,brass or steel plug,ferrule,etc....etc.... under the sun.
Back 45 years ago, i didnt even know what a "wave washer" was til i started looking thru the Dorman display. I spent probably an hour there that day.
So.....find a Dorman display and youll find your 1 1/4" copper washer.
The worst part is getting the rummy behind the counter to figure out how to price it.
Good Luck,
H Online: Content
You're going to find that the plug isn't sealed to start with- - - -there's a tiny air bleed hole drilled into it. The gasket is just a dust seal, and a piece of thin cardboard trimmed to fit will work well. If the bleed hole gets plugged up and a vacuum develops in the reservoir, air can be drawn past the wheel cylinder cups as the brake pedal is released after a stop.
Sounds good. I'll either find the Dorman rack and browse for a gasket, or do the cardboard cutout thing. Thanks!
Hey Jerry, I hate to but in but you recon that might be what's going on with my brakes? I'll bleed them, let the truck set a day or two, no brakes. There are no leaks that I can find. Bleeding the old fashioned way. Don't know. Maybe that little hole is stopped up! Thanks folks for letting me but in for a second
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
