7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible), 76 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#1223625 07/03/2017 12:52 AM
I just finished bleeding my 49 half ton's brakes and when I went to put the fill plug back into the master cylinder, I noticed that a thin "gasket"(?) was dangling from the plug. I am guessing a gasket or some sort of seal is needed to keep the system air tight, but where can these be found? After looking at the usual Chevy truck online part sites I found MC rebuild kits that include a fill plug/cap and an o-ring that looks like it might go into the fill plug/cap, but I have not found just the gasket or o-ring.
Is a seal necessary, or will keeping the plug tight be enough of a seal?
Weeellllllll, it might be OK without a gasket. The cork casket on my 51 is broke in one place and I've been babying it for a couple of years. When it totally fails I plan to make a replacement from cardboard (as from a shoe box or such, not brown cardboard). A ball peen hammer and a couple appropriate sized sockets are all that's required.
RonR
1970 340 Duster
1964 CJ5
A GOOD auto parts store will have a Dorman section. Orange and Black steel cabinets with every fitting,washer,brass or steel plug,ferrule,etc....etc.... under the sun.
Back 45 years ago, i didnt even know what a "wave washer" was til i started looking thru the Dorman display. I spent probably an hour there that day.
So.....find a Dorman display and youll find your 1 1/4" copper washer.
The worst part is getting the rummy behind the counter to figure out how to price it.
Good Luck,
You're going to find that the plug isn't sealed to start with- - - -there's a tiny air bleed hole drilled into it. The gasket is just a dust seal, and a piece of thin cardboard trimmed to fit will work well. If the bleed hole gets plugged up and a vacuum develops in the reservoir, air can be drawn past the wheel cylinder cups as the brake pedal is released after a stop.
Sounds good. I'll either find the Dorman rack and browse for a gasket, or do the cardboard cutout thing. Thanks!
Hey Jerry, I hate to but in but you recon that might be what's going on with my brakes? I'll bleed them, let the truck set a day or two, no brakes. There are no leaks that I can find. Bleeding the old fashioned way. Don't know. Maybe that little hole is stopped up! Thanks folks for letting me but in for a second
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
