1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1223800 07/04/2017 8:54 AM
I have a 1997 gmc sierra (4x4) that is no longer drivable. I also have a 1952 chevy truck that I want to do a resto-mod on. My question is: Can I use the differential, axle, shocks, etc from the 1997 gmc and put them on the 1952 chevy? The 1997 measures 60" across from where the axle bolts on to the backing plate.
52Steve #1223812 07/04/2017 1:00 PM
You need to measure from where the rims touch the rear rotors or brake drums. That maybe what you meant, if not, you measured from the wrong location. I suspect it's way to wide. Also, shocks, springs and sway bar will be for a much heavier truck, ride may suffer.
Joe
52Steve #1223831 07/04/2017 2:48 PM
Crusing in the Passing Lane
Are both same weight(1/2 ton or 3/4 ton) or different? Do the wheel bolt patterns match? How do the widths compare?
Ed
52Steve #1223888 07/04/2017 10:34 PM
You'll find that measuring from the wheel mount surfaces that the '97 axle will be too wide.
Bill Burmeister
52Steve #1223938 07/05/2017 5:34 AM
Thanks for all the responses. I guess in some way I knew it would be too wide, but I was holding out hope since it wouldn't have cost me any $$$.
