5 members (FAST55, MickeyP, mo2cyl, Gdads51, 66flea), 87 guests, and 1 robot.
Topics128,049
Posts1,055,652
#1222116 06/21/2017 12:19 AM
M Online: Content
Are there any decent working or quality antennas on the market for original radio in a 53 Chevy PU?. Have not drilled any holes yet, but leaning toward original. Jim Carter says he has them, but wondering about the quality.
Thanks in advance!!!
mo2cyl #1222124 06/21/2017 12:50 AM
Go with the Jim Carter product. It comes with the template and instructions so you drill your hole in the correct location. Two of my trucks have his antenna and they are great quality.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
M Online: Content
Thanks Kent!
mo2cyl #1222202 06/21/2017 9:23 PM
Many vendors sell the same expensive/correct reproduction 47-55st antenna (sold by Jim Carter, etc).
Here is the template/instruction sheet that they all provide.
mo2cyl #1222231 06/22/2017 1:47 AM
M Online: Content
Tim,
You got that right about expensive! Hopefully the quality is as high as the price? It will be the only piece of chrome on my truck. He He He.
Thanks for the template.
Regards
mo2cyl #1222258 06/22/2017 7:23 AM
Kevin,
The cowl trim piece is chromed, but the antenna is stainless steel.
mo2cyl #1222299 06/22/2017 5:02 PM
M Online: Content
I do have a piece of stainless on the visor. Hopefully it will clear that as well. Just eyeballing it, it will be close!!!
mo2cyl #1223729 07/03/2017 11:25 PM
Moderated
Moderated
Has any one installed a power up and down antenna, if so where did you put it. I have a 1954 that Iam rebuilding and would like to have decent reception
mo2cyl #1223751 07/04/2017 1:39 AM
I have not seen a power antenna for these AD trucks.
1951 1 Ton Completed
Moderated by  truckernix
