| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | My 1966 stepside is still at the body shop. On the driver's side, there is a bracket that the spare tire bolts to. One arm of the bracket goes through a hole in the fender. In that hole, when I dismantled the truck was a rubber grommet. The hole is 1 7/8 inches and the old grommet measures 2 inches on the outside. I've looked at all the usual parts distributors and have found nothing. Additionally, I contacted the folks at Steele and they couldn’t help either. Ideas? Thanks - | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | So your tire is a fender mount, and not under the bed. Hmmm!!??!! I sure wish I knew of a scrap yard with one of those fender mounts. Is the rubber piece really necessary? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I have the same spare mount as Tim-o. I too am missing the rubber grommet. May have to fabricate my own.ðŸ›
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Have you guys tried the miscellaneous hardware section of your local hardware store? They usually have grommets in various sizes, but that large may be a stretch. I recall that the old Model A side-mount spare tire arm had a similar grommet thru the splash apron. You might try contacting the Antique Ford (  ) places with the specs. [on edit] how about this one?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | Thanks folks for your input. The tire mount is indeed on the driver's bedside - right behind the cab. Is the grommet necessary? Probably not except it does make the whole thing look a little finished. I too considered making my own. I restored a CJ2A a few years ago and had to make a larger grommet smaller with some strategic cutting with an exact-o knife. The grommet suggested above by klhansen looks workable to me! I'll order some up and see what happens. I appreciate your help - you guys always come through. Tim-o | | |
