1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 105 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 105 | I just finished bleeding my 49 half ton's brakes and when I went to put the fill plug back into the master cylinder, I noticed that a thin "gasket"(?) was dangling from the plug. I am guessing a gasket or some sort of seal is needed to keep the system air tight, but where can these be found? After looking at the usual Chevy truck online part sites I found MC rebuild kits that include a fill plug/cap and an o-ring that looks like it might go into the fill plug/cap, but I have not found just the gasket or o-ring. Is a seal necessary, or will keeping the plug tight be enough of a seal? | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Weeellllllll, it might be OK without a gasket. The cork casket on my 51 is broke in one place and I've been babying it for a couple of years. When it totally fails I plan to make a replacement from cardboard (as from a shoe box or such, not brown cardboard). A ball peen hammer and a couple appropriate sized sockets are all that's required.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | A GOOD auto parts store will have a Dorman section. Orange and Black steel cabinets with every fitting,washer,brass or steel plug,ferrule,etc....etc.... under the sun. Back 45 years ago, i didnt even know what a "wave washer" was til i started looking thru the Dorman display. I spent probably an hour there that day. So.....find a Dorman display and youll find your 1 1/4" copper washer. The worst part is getting the rummy behind the counter to figure out how to price it. Good Luck, | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | You're going to find that the plug isn't sealed to start with- - - -there's a tiny air bleed hole drilled into it. The gasket is just a dust seal, and a piece of thin cardboard trimmed to fit will work well. If the bleed hole gets plugged up and a vacuum develops in the reservoir, air can be drawn past the wheel cylinder cups as the brake pedal is released after a stop. Jerry
| | | | | Joined: Nov 2013 Posts: 105 'Bolter | | 'Bolter Joined: Nov 2013 Posts: 105 | Sounds good. I'll either find the Dorman rack and browse for a gasket, or do the cardboard cutout thing. Thanks! | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Hey Jerry, I hate to but in but you recon that might be what's going on with my brakes? I'll bleed them, let the truck set a day or two, no brakes. There are no leaks that I can find. Bleeding the old fashioned way. Don't know. Maybe that little hole is stopped up! Thanks folks for letting me but in for a second . | | |
