Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Ponchogl, 1955 1 Series, homer52), 113 guests, and 3 robots.
Topics128,283
Posts1,058,505
Members48,490
#122322 10/03/2006 1:58 PM
Apprentice
Apprentice
1 Offline
I just completed painting my truck disassenbled, with single stage urethane. It makes sence to me the color sand and polish after the truck is assembled, probably by next spring. Is there a problem waiting that long to sand and polish or should it be done while the paint is fresh?
I don't see where that would be a problem, it'll give the paint plenty of time to cure. Don't install ant chrome or trim until after you color sand and polish, though. And make sure to get quality sandpaper, 600-2500/3000 grits will do.
I also saw your question on windshield installation, I'd suggest finding a glass professional to put it in. From my own experience, trying to do it yourself is a real PIA. A glass shop will have the correct tools to do the job, and most will give a guarantee against leaks.
Bill Burmeister
It is my understanding that after 24/48 hours a single-stage urethane is much harder to color sand. Were there any recommendations on the product sheets for the paint you used?
I don't know how urethane is, but I waited about 4 months to color sand acrylic enamel and it was HARD to sand. I would say the sooner the better.
Keith
If it were easy they'd have grade schoolers doing it!
When you say "Hard to sand", do you mean the paint was hard and required more effort or you did not get good results sanding?
I painted the '55 with single stage, and had no problems sanding. It didn't seem to mater wheather the parts were frshly painted or had sat for some time.
Again, it realy depends on the materials-quality sandpaper is a must. Sanding wet helps too.
Bill Burmeister
For the best results I would sand after 24 to 48 hrs then buff the next day you will get the shine back much quicker, the longer you have to buff the greater you risk is of a screw up. your paint should say how long to wait before buffing. follow their insructions
Popa Kents Body Shop
I would wet sand it now and then buff it out in the spring. I painted my hood and doors a year ago then wet sanded them two days later. I waited a year before I buffed them and they came out just fine.
The crew that works on the \'42 --Sara, Hannah and Abby
Quote
more effort required, and quality of sandpaper wasn't the issue, the paint had just cured so hard that sanding was difficult.
Keith
