8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny),
125
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Can someone verify I've got the right procedure to for a '60 235 after replacing the head? - Warm the engine then let it cool down - Follow torque sequence - One bolt at a time, back off 1/2 turn then torque to 90-95 pounds. No need to do in steps like 30, 60, 90.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Tim, 8-5 just says to torque to 90-95 so does that mean don't back off first just set torque wrench to say 93 and torque?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dennis,
Wait to hear from a pro. I have done it both ways (in the described pattern). I have never had a problem. Now, I do it to 75, all the way around; then, to spec, and then again, to spec. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Never seen a factory or manufacturer's recco to back off anything. | | | | | Joined: May 2015 Posts: 11,016 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,016 | Never seen a factory or manufacturer's recco to back off anything. Right. The only time I've seen that is for wheel bearings. Torque down to seat while rotating, back off and torque again, then back off 1/x turns. That's better than the "Torque 'em down till the break and back off a 1/2 turn" method.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
