1 members (Steelonsteel), 44 guests, and 3 robots.
Topics128,090
Posts1,056,024
Members48,432
#1222752 06/26/2017 1:29 PM
Hello, I have a newer water pump that I believe was installed in correctly by the previous owner or a mechanic which has a 5/8 pulley and not 3/8 which would correctly match the balancer and alternator. Is there a source of a 3/8 pulley somewhere or am I stuck buying a whole new water pump with the correct pulley. The pulley is the cast type BTW.
Thanks for the input.
I have a 54 235 1/2 ton chevy
posey #1222820 06/26/2017 10:52 PM
If you cannot find just the pulley, you can buy a new pump with the correct pulley, then put in on your engine, then mothball the old pump for when your new one eventually fails. At that time you can swap pulleys from your worn out "new" pump to your good old mothballed pump.
posey #1222827 06/26/2017 11:29 PM
That 54 235 engine will have the high water pump like a 216- - - -the pulley is not removable unless you want to press it on and off.
posey #1222871 06/27/2017 12:52 PM
One other question, Why does it say on some pulleys are not made for Hydramatic trannies? Is there a place to connect a cooler or something?
I have Hydramatic.
posey #1222890 06/27/2017 3:02 PM
Can you post a link/address to that information?
My 1954 Hydra-Matics' pulleys are the same as on my 1954 manual transmission trucks.
posey #1222918 06/27/2017 6:07 PM
I've read that the 3/8" belt will just ride lower in the 5/8" groove (than the large belt) but give acceptable life, since the belts all have the same shape - the smaller one is just not using the top area of the big pulley.
Why are there different sizes? Different load capacity: the larger belt needs less tension for the same load and will last longer, but higher inertia, weight and cost.
panic #1223025 06/28/2017 2:07 PM
In my case the belt just contacts the bottom of the pulley and slowly wears away the belt leaving this black rubber dust over the sides of the engine. You are also over tightening the belt in order for it to turn the pump and fan.
posey #1223029 06/28/2017 2:32 PM
Yikes... you can run a narrower belt in a wider pulley, but the belt should NEVER be allowed to bottom out in that pulley.
~ Dave
posey #1223096 06/28/2017 11:26 PM
Crusing in the Passing Lane
Second, never touch the bottom. Get the right belt to start with.
Ed
