7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Has anyone used a speedway 21 circuit wire harness in their 47-53 Chevy or gmc truck if so where was fuse block placement Thanks for any and all help
This is no longer fun
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Assuming:
1. The old fuse boxes were mounted outside firewall. 2. The new box has the newer style fuses. (you are not trying to replicate exact original) 3. You want the box protected from heat and the environment.
Then: You want the box mounted inside, usually upper left of your left foot. In a place that is somewhat accessible but out of the way. Bolt in on and run your various harness branches "to and fro". We will be glad to help as you progress.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Thanks I'm looking for ideas I filled in all the holes on the firewall and don't want any new ones so looking to see where others have mounted new fuse boxes I should have purchased the mini fuse block Thank you keep ideas coming
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If there are any bolts that come thru firewall threads, you can use longer bolts there, which create a stud inside. With spacers and nuts, you can mount the box to the "studs". OR...You can find structure/holes inside that you can attach a bracket to. Attach box to your fabbed bracket. OR... You can create your own studs with carriage bolts. Head to outside of firewall for a clean, flush look. This bolt is sometimes called a "Stovebolt". Apropos aye? OR... You can rivet a bracket inside of firewall, rivet head on outside of firewall. Mount box to the bracket.
Your limiting yourself with the idea of no holes in firewall. The holes that you drill for the box will be filled by a bolt anyway. Is this a 5 star restoration? If it is, the box would be mounted outside on firewall. I would assume you realize that mounting to firewall is very practical. Most boxes in the Stovebolt world are mounted to the firewall. Many kits include a bracket and instructions to do so.
Your harness runs to engine/front lights and to dash (gauges, switches, column are on the left) and to rear lights (only 4-5 wires). The central protected accessible distribution location is....... inside, upper left of your left foot. Tim asked you what year, assume your username says it.
Chevy finally came to their senses and mounted the acid filled, fume generating battery outside cab and some corrosion sensitive electrical parts inside cab. Took them awhile. Electrical, and especially automotive electrical, was an emerging science.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | A lot of people put it under the seat. I put mine under the dash left of the steering column | | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | My truck is a 52 1/2 ton thanks for feed back would like to mount fuse block under seat but the wires would have to be extended to reach dash so I will have to make mounting bracket think off the steering column support bracket Again thanks for feedback Robert
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That is a good decision. Nothing is easy. Gotta go with what fits your comfort zone.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Yeah, upper left of foot placement, those guys must have been midgets, normal foot size would works, try moving up higher.
Ed
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Made a bracket today mounted fuse box on the support bracket from firewall to dash put a slight bend in my bracket so won't be completely upside down if I need to check or change a fuse
| | | | | Joined: Sep 2010 Posts: 496 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 496 | Hi Everyone,
Not to hijack the thread, but I have a related question.... I too am using the Speedway wire harness and have decided to mount it to the inside of the firewall of my 1953 3100. My question is do I have to remove a section of the padding that covers the firewall or can I just mount the fuse block directly over the padding? Either way it isn't a big deal, I just want to do it right. I am using one of the old fuse holder holes and a new hole for the second mounting bolt. It made it easy to run the new wires through the old grommets in the old locations. Thanks for the advice. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd use "standoffs" so it's not actually crushed against the pad to be tight
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | As Bill said, use spacers. Tubular, hex or other. Put a hole in the pad a little larger than the spacers. Putting a nice hole in an already installed pad is not all that easy. A drill will split the plastic, wind up the jute and rip it all out. Possibly a soldering iron will do the trick with a standby water squirt bottle so the jute does not catch fire....or just heat up the spacer and melt thru. Squirt the jute right afterwards. It will dry later.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2010 Posts: 496 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 496 | Thanks for the advice! Looks like a short trip to the hardware store and I'm back to work. | | |
