| | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | My 58 Viking 60 v8 283 truck has original gauges. I replaced the gas tank and sending unit soon after buying it last year and got it running. The fuel gauged worked. I've driven it 3 trips 1/2 mile or less. Now the fuel gauge does not work. Yes the sending unit ground wire is well grounded. The sending unit is new. I pulled the sending unit and ran a ground wire jumper to battery ground post and jumper wire from unit to gauge Nothing when I moved float Wire from switch to gauge seems fine. Cleaned terminals and wire connectors. Wires test out fine Sooooo how do I test the actual gauge to see if that's where problem is. Thanks for any advise or opinions. I not only love this site but need it Ivelearned so much here ! THanks to all who contribute. | | |
