1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#1222639 06/25/2017 1:29 PM
Can someone verify I've got the right procedure to for a '60 235 after replacing the head?
- Warm the engine then let it cool down
- Follow torque sequence
- One bolt at a time, back off 1/2 turn then torque to 90-95 pounds. No need to do in steps like 30, 60, 90.
Dennis
40 Chevy 1/2 ton
Dennis,
Follow the instructions/specifications in the Shop Manual (first/spec page, and 8-2 & 8-5), or, follow the instructions in this write-up.
Tim, 8-5 just says to torque to 90-95 so does that mean don't back off first just set torque wrench to say 93 and torque?
Dennis
40 Chevy 1/2 ton
Dennis,
Wait to hear from a pro. I have done it both ways (in the described pattern). I have never had a problem. Now, I do it to 75, all the way around; then, to spec, and then again, to spec.
' Offline
This is the way I did my 235 cylinder head .
photo@photobucket
http://i669.photobucket.com/albums/...ead_Bolt_Torque_Pattern__zpszhamcg4a.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Never seen a factory or manufacturer's recco to back off anything.
Right. The only time I've seen that is for wheel bearings. Torque down to seat while rotating, back off and torque again, then back off 1/x turns.
That's better than the "Torque 'em down till the break and back off a 1/2 turn" method. wink
