7 members (MickeyP, jmoore, GMCJammer51, TPR57C, Eisenholtz, 55shaker, 1 invisible),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,627 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 28 | can anyone give me the correct part number and where to buy etc for the axle nut removal tool. also, is the passenger side reverse threaded?
49chev6400.webs.com
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | On my '50 Chevy COE the passenger side axle spindle is NOT reverse threaded. Regarding the tool I have only seen one on Ebay in the past nine years of searching. A friend made me one with a section of pipe with a socket welded on one end and the other tig welded 6 studs to fit the nut. The real tool also has an extension that fits inside the spindle to better hold it in the proper orientation.
Most people use a punch placed into the slots in the nut. Over time this distorts the slot, especially if someone has had to really punish the punch to get the nut to move.
Kent | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | I've always made those tools, using a piece of pipe with lengths of 1/4" key stock welded to the outside and a hole drilled in the end for a pry bar to be used for turning it. Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Get a nut off with a punch as described, then take one to your Flaps and keep trying the 4 wheel drive versions of removal sockets until you find one that fits. I found mine at Autozone.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I forgot to mention that it would be impossible to set the nut to the proper torque when reassembling, in order to set the bearing preload, without some sort of tool. I don't know how you do it tightening the nut with a punch. So after you get it apart, get one made like Jerry suggests and keep it with your truck.
Kent | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | I'm pretty sure a few million of those nuts have been "torqued" with the hammer and punch method over the past decades. Take the slack out with the inner nut, add a little preload, then use the outer one as a lock, with a tabbed lock washer in between the two. Once I get a nut off, I put pieces of key stock in the slots of the nut and use a radiator hose clamp to secure them, then I use a piece of pipe or a worn out socket as a center piece. Weld or braze the square stock to the center. If a square drive socket is used, it's easy to use a torque wrench for accurate tightening. More likely, it will get the procedure an oldtimer taught me 60 years ago- - - - - -"Give 'er a good grunt!" Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I love it..."Give 'er a good grunt"...that pretty much sums up what these old trucks were designed to withstand.
