0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Hi guys 'n gals.. I know these questions have been asked somewhere but... I am installing a new bed on my '49. Because I have airbags I need to raise the bed about 2 inches. First what kind of blocks [and/or where can I get them] should I use. Also when we weld in the new angle to the bed sides I want to put stainless covers over them... (so as to not discolor) Does someone sell those pre punched. And lastly when installing covers won't there be a bit of a gap on the bed side of the covers are not bolted to the sides? Thanx! Osidejack
Try prayer as the first response rather than a last resort ...
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The blocks are just Alder I believe and I would have to measure but 2x2x2? You could simply cut your own to the desired height. It would be tall and may be a bit wobbly. If you are building a street machine why not build them out of square tubing? Put rubber pads in and that may solve your issue. I have never used the covers, they are sold as described. In two spots at the fender bolts they are secured, you could add small bolts at the ends to kill the gap. | | |
